Antistatic Test at 100V on Ball Valve
Good morning,
can someone help us about how to perform Antistatic Test at 100 V d.c. on Ball Valves? Normally, this test is performed using a power source not exceeding 12 V d.c. but in this case the power source is to be 100 V d.c.
Alternatively, our client asks to perform the same test on a test sample. How to perform this test also in a safe condition?
Many Thanks in advance for your prompt reply.
Marco
Marco
RE: Antistatic Test at 100V on Ball Valve
100 Vdc test is normally done for shoes and other type of insulation to prove it does not conduct static electricity. I cannot think for any reason why someone would want to check that there cannot be any electrical flow path between a ball, stem, and body. There are pretty tight metal-to-metal clearances in the assembly where arcs will most likely occur.
The requirement just does not make sense.
