Back to basics flow vs density relationship in an orifice 1
bouk
Petroleum
DK
Hi guys,
Why is the relationship between the mass flow and the density not linear in flow through an orifice?
Pressure?
Maybe it's me but I'm not understanding the question. Can you elaborate a bit more than one line please?
A snip of the equation would be lovely.
Good Luck,
Latexman
Apologies, here's a bit more background. If I have a mass rate of gas (Mol wt. 20) and want to read off a graph with the x-axis being a rate of air (StdL/hr) what the equivalent rate of air is, how would one do this?
I used the ideal gas relationship (PV = nRT) to take the mass rate of gas (kg/hr), divide by the mol weight of air and convert this molar rate to StdL/hr.
My colleague said that flow through an orifice was proportional to the square root of the density (and thus molecular weight) and not directly proportional, and I wondered what (physically) makes this the case and why my logic isn't following?
What's on the Y axis?
An orifice as I'm sure you know measures flow by looking at the delta P and other physical attributes of the orifice.
Flow is proportional to the sqr root of the delta P. So given that density is a function of pressure, then the flow could be said to be proportional to the sqr root of the DELTA of the densities.
however you are measuring the pressure so just use the delta P to establish flow rate. Not this will be actual flow at whatever pressure you're flowing at so would then need a further conversion to get to standard conditions
@pierreick,
I appreciate the thought but that's a copyrighted document in a public forum. I suggest you remove it again...
Best regards, Morten
--- Best regards, Morten Andersen
Thankyou all for the responses. That has given me the useful equations and background information I needed.
My curiosity now stems even further as to how those relationships/equations were derived in the first place, but I guess that's like asking a question why does gravity act the way it does?! I'll just accept that it's forces at play that cause the behaviour of the gas in the way presented in the equations.
PS - No need to reply to my rhetorical question above :)
