Contact US
Parts List keeps re-ordering
Hi All,
I have created a parts list in a large assembly drawing.
The parts list its-self is from a template i have created and reads part attributes to populate fields:-
'SUPPLIER, PART NUMBER, DESCRIPTION'
With some auto generated 'system' fields for 'ITEM No & QTY'.
I have one fields which i need to manually populate with the zone / grid reference of where the item can be found in the drawing. When i populate this field, the items in the parts list re-order themselves. Is there a setting somewhere to turn this behavior off?
ps. NX11
Thanks in advance & Cheers
B
RE: Parts List keeps re-ordering
I think i have cracked it!
In the part list template part, i selected the 'zone' column, then in the 'settings' > Columns > Behavior... ensure that 'Key Field' is not selected.
Cheers,
B
This should not be the reason.
A key field works such that if there are multiple different values on the same item , it will get different lines.
I think the following example will clarify:
Imagine a parts list för a car assembly .
the front wheels are the same article but the placement= description are "left front and "right front".
The parts list header:
item no | qty | part number | description
If the "description" column is a key field you will get two lines:
1 | 1 | 12345 | Left front
2 | 1 | 12345 | right front
If the description column isn't a key field you will get one line:
1 | 2 | 12345 | ...
where the "..." indicates "this cell contains multiple values".
The solution you probably should look at is "Right click - Sort"
This dialog sets the sort order / columns to sort on of the parts list.
probably the zone column should not be used for sorting ?
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.smile
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
