Walk-in Cooler Floor Live Load
XR250
5,969
I am designing a wood platform for a portable walk-in cooler. It is 8 feet wide, 20 feet long, by 7 feet tall. The cooler sits on an integrated steel frame.
Does anyone know what floor live load I should design for?
Thanks.
From the DOD's Unified Facilities Criteria, UFC 3-301-01, Structural Engineering, Appendix G Minimum Uniformly Distributed Live Loads and Minim Concentrated Live Loads:
49. Refrigeration storage rooms
Dairy 200psf​
Meat 250psf​
Vegetable 275psf​
Just guessing your portable won't be as heavily loaded - especially since you're going with a wood platform. I'd probably not go less than 125, though. You'll have some amount of refrigeration equipment, and if they pack it tight it could get quite heavy.
