Steam Flowmeter
Steam Flowmeter
I've installed vortex flowmeter for steam flow with initial design of superheated 45kg/cm2 and 400c temp. However, the temp now dropped to 240 and pressure 37kg/cm2. I checked now that the steam is bo longer superheated, how should i adjust the setting in flowmeter? because the density is now jumping to 800 kg/m3
RE: Steam Flowmeter
- fluid > steam > saturated or superheat
- Density: setting for the density at reference operating pressure and temperature reference conditions.
- % water mass in saturated steam
- Density calc for saturated steam, saturated Temp; saturated Pressure
The device manual will have the configuration menu
RE: Steam Flowmeter
RE: Steam Flowmeter
The conversion from volumetric flow to mass flow is done with absolute pressure and temperature measurements and calculation.
RE: Steam Flowmeter
RE: Steam Flowmeter
