Small Metric Size GLT Rubber O-Ring Supply Source Needed
jimbod20
Aerospace
I moved this post from the rubber engineering forum this am. I think the mechanical seal engineering forum is a more appropriate forum for this inquiry.
I need two specific o-rings that I cannot readily find. Are there any recommendations on where I can find and buy these o-rings? Both are a metric size in the Viton GLT rubber formulation.
#1 size 1.5mmx6mm
#2 size 1.5mmx8mm
