electrical429
When you have a dual ratio CT, say 1000/500/1, and the thermal rating of CT is 100%. Does this mean that on the 1000/1 ratio you will 1000 A thermal rating and on the 500/1 ratio you will have 500 A thermal rating. Or is thermal rating independent of the ratio you choose and it will be 1000 A in this case for both ratios?
