Equivalent Horizontal Force and P-Delta effects
As-Lag
GB
Hello.
I am trying to understand the principles of sway of a column. The column is a fixed base cantilever with a heavy axial load and a wind-action as a point-load at the top of the column. No lateral UDL.
I have been doing the maths for the second-order analysis to calculate the sway manually and checking my results against a SkyCiv model, and my results are very close to the Computer Analysis. I have been using the method to calculate the P-delta and P-Delta as described in Appendix 8 of the American Code for steel (B1 and B2 method).
In the Eurocodes, I have to apply an Equivalent Horizontal Force (EQH) to the top of the column which I have also calculated.
My question is on how to deal with the EQH with the sway analysis. Should I include the force ΦNEd into the P-Delta B2 factor or should I calculate the moment created by the force seperately and add it to sum of the moments created by the first and second-order analysis?
Many thanks. Dan
