Structure Design Using Slope-Deflection Equations and Matlab
Hi there, I was wondering if someone could help me.
I am designing a simple structure. I have attached a diagram and I am using the slope-deflection equations and using Matlab. Unfortunately I am getting strange results that I think are wrong. For the rotations at the joints I am getting zero which cannot be correct.
Here is my Matlab code:
clear
clc
% data
E = 2e+08;
I = 0.002;
EI = E.*I;
L1 = 5;
L2 = sqrt(5.^2 + 5.^2);
q = 100;
FEM1 = q.*L1.^2./12;
FEM2 = -FEM1;
% Symbolic mathematics
syms X1 X2 X3 X4 X5 X6 X7 X8 X9 X10
X1 = 0; X3 = 0; X5 = 0; X7 = 0;
X2 = -X8;
X4 = -X6;
X9 = -X10;
M1i = 4.*EI./L1.*X1 + 2.*EI./L1.*X2;
M1j = 2.*EI./L1.*X1 + 4.*EI./L1.*X2;
M2i = 4.*EI./L1.*X3 + 2.*EI./L1.*X4;
M2j = 2.*EI./L1.*X3 + 4.*EI./L1.*X4;
M3i = 4.*EI./L1.*X5 + 2.*EI./L1.*X6;
M3j = 2.*EI./L1.*X5 + 4.*EI./L1.*X6;
M4i = 4.*EI./L1.*X7 + 2.*EI./L1.*X8;
M4j = 2.*EI./L1.*X7 + 4.*EI./L1.*X8;
M5i = 4.*EI./L1.*X2 + 2.*EI./L1.*X4;
M5j = 2.*EI./L1.*X2 + 4.*EI./L1.*X4;
M6i = 4.*EI./L1.*X4 + 2.*EI./L1.*X6;
M6j = 2.*EI./L1.*X4 + 4.*EI./L1.*X6;
M7i = 4.*EI./L1.*X6 + 2.*EI./L1.*X8;
M7j = 2.*EI./L1.*X6 + 4.*EI./L1.*X8;
M8i = 4.*EI./L2.*X2 + 2.*EI./L2.*X9;
M8j = 2.*EI./L2.*X2 + 4.*EI./L2.*X9;
M9i = 4.*EI./L1.*X9 + 2.*EI./L1.*X10 + FEM1;
M9j = 2.*EI./L1.*X9 + 4.*EI./L1.*X10 + FEM2;
M10i = 4.*EI./L2.*X10 + 2.*EI./L2.*X8;
M10j = 2.*EI./L2.*X10 + 4.*EI./L2.*X8;
M11i = 4.*EI./L1.*X4 + 2.*EI./L1.*X9;
M11j = 2.*EI./L1.*X4 + 4.*EI./L1.*X9;
M12i = 4.*EI./L1.*X6 + 2.*EI./L1.*X10;
M12j = 2.*EI./L1.*X6 + 4.*EI./L1.*X10;
% Solving
Joint2 = M1j + M5i + M8i == 0
Joint4 = M2j + M5j + M11i + M6i == 0
Joint6 = M3i + M6j + M12i + M7i == 0
Joint8 = M4j + M7j + M10j == 0
Joint9 = M8j + M11j + M9i == 0
Joint10 = M9j + M10i + M12j == 0
Answer1 = solve(Joint2,X6)
Answer2 = solve(Joint4,X6)
Answer3 = solve(Joint6,X6)
Answer4 = solve(Joint8,X6)
solve(Answer1, Answer2)
I am hoping someone here knows how to use Matlab and is familiar with slope=deflection equations that can help me.
Kind regards
clear
clc
% data
E = 2e+08;
I = 0.002;
EI = E.*I;
L1 = 5;
q = 100;
FEM2 = -FEM1;
X2 = -X8;
X4 = -X6;
X9 = -X10;
% Solving
Kind regards
RE: Structure Design Using Slope-Deflection Equations and Matlab
You need to list all the relevant Xs in each solve line, not just X6 , and I am fairly convinced your last line won't work.
Cheers
Greg Locock
Since the structure and the load are symmetrical, you could write slope-deflection equations for only half the joints. In your case, that would be joints 1, 2, 3, 4 and 9. Of course, if you load the structure unsymmetrically, you will need to write equations for every joint.
The slope deflection method, for any member spanning from A to B has two equations which are easily verified, namely:
MAB = MFAB + 2EI/L *(-2θA - θB)
MBA = MFBA + 2EI/L *(-2θB - θA)
EDIT: There are only three unknown rotations. They occur at nodes 2, 4 and 9 (rotation at nodes 1 and 3 is zero), so it should result in three simultaneous equations which should be soluble by hand methods. From that, the moments can be determined at all nodes.
BA
[Edit]-added these comments
1. MAB = MFAB + 2EI/L *(-2θA - θB);
2. MBA = MFBA + 2EI/L *(-2θB - θA);
Matrix becomes
MBA = [MFBA - 2EI/L - 4EI/L][θB]
since this expression is 'linear' use "\" not "inv" function. You can try "inv", I think that takes lots of computation time. Like I said, it has been a while I used MATLAb but I hope this helps
Have you gone through my slope-deflection equations at all? Because I'm not sure if the error is with my calculations or something to do with my Matlab code. I am using Matlab simply to reduce number crunching and make the calculations easier on myself. I downloaded the symbolic toolbox for Matlab so I could use symbolic mathematics.
Thanks again.
Here is an updated attached diagram, so you can see how I have used Mi and Mj.
It Matlab I have replaced the theta1, theta2, theta3 etc... with X1, X2, X3 etc...
BA
[Edit]
Joint6 = M3i + M6j + M12i + M7i == 0 should be Joint6 = M3j + M6j + M12i + M7i == 0
clear
clc
close all
L = 5;
q = 100
FEM1 = q.*L.^2./12;
EI = 400000;
FEM2 = -FEM1;
syms X1 X2
M1i = 4.*EI./L.*X1 + 2.*EI./L.*X2 + FEM1 == 0;
M1j = 2.*EI./L.*X1 + 4.*EI./L.*X2 + FEM2 == 0;
answer1 = solve(M1i,X1)
answer2 = solve(M1j,X1)
theta2 = solve(answer1)
theta1 = -theta2
PS: thanks BA retired for your help also!
Unfortunately, changing the equation using the j component still gives a result of X6,X8,X10 = 0. How have you found the code in your Matlab?
Try deleting the following lines from your code. The program should find all rotations without these lines.
X2 = -X8;
X4 = -X6;
X9 = -X10;
BA
Sorry, I failed to save the MATLAB file I was working on initially and was busy as well. I have a reminder set for me to go through your scripts again but I have scribbled something down to help us check. I would like you to make "E = 2e8", "I = 0.002", "L1 = 5", "L2 = sqrt(5.^2 + 5.^2)" as comments. Also instead of having FEM1 as an equation, just input 208.333. Run the script up to "Joint10 = M9j + M10i + M12j == 0".
I think the problem will come from "Answer1 = solve(Joint2,X6) Answer2 = solve(Joint4,X6) Answer3 = solve(Joint6,X6) Answer4 = solve(Joint8,X6)" so I want us to be sure. What I am seeing is, MATLAB is solving equation "Answer1 = solve(Joint2,X6)" for theta 6 but there's no theta 6 in Joint 2? For a system of equations, solutions are also dependent on other equations but I don;t see it in the MATLAB (from the way I see it). Lets say you have 3 unknowns and 3 equations, you need to solve them "simultaneously" but that's not done here. When you're done going through my attachment after making those changes I mentioned up there, try rewriting the system equations for the joints.
I will paste the entire script and command window:
% data
E = 2e+08;
I = 0.002;
EI = E.*I;
L1 = 5;
q = 100;
FEM2 = -FEM1;
% Solving
Joint2 = vpa(M1j + M5i + M8i == 0,3)
Joint4 = vpa(M2j + M5j + M11i + M6i == 0,3)
Joint6 = vpa(M3j + M6j + M12i + M7i == 0,3)
Joint8 = vpa(M4j + M7j + M10j == 0,3)
Joint9 = vpa(M8j + M11j + M9i == 0,3)
Joint10 = vpa(M9j + M10i + M12j == 0,3)
Answer1 = vpa(solve(Joint2,X2),5)
Answer2 = vpa(solve(Joint4,X4),5)
Answer3 = vpa(solve(Joint6,X6),5)
Answer4 = vpa(solve(Joint8,X8),5)
Answer5 = vpa(solve(Joint9,X9),5)
Answer6 = vpa(solve(Joint10,X10),5)
theta = solve(Answer1, Answer2, Answer3, Answer4, Answer5, Answer6)
Command Window:
Joint2 =
8.66e+5*X2 + 1.6e+5*X4 + 1.13e+5*X9 == 0.0
Joint4 =
1.6e+5*X2 + 1.28e+6*X4 + 1.6e+5*X6 + 1.6e+5*X9 == 0.0
Joint6 =
1.6e+5*X4 + 1.28e+6*X6 + 1.6e+5*X8 + 1.6e+5*X10 == 0.0
Joint8 =
1.6e+5*X6 + 8.66e+5*X8 + 1.13e+5*X10 == 0.0
Joint9 =
1.13e+5*X2 + 1.6e+5*X4 + 8.66e+5*X9 + 1.6e+5*X10 + 208.0 == 0.0
Joint10 =
1.6e+5*X6 + 1.13e+5*X8 + 1.6e+5*X9 + 8.66e+5*X10 - 208.0 == 0.0
Answer1 =
- 0.1847*X4 - 0.1306*X9
Answer2 =
- 0.125*X2 - 0.125*X6 - 0.125*X9
Answer3 =
- 0.125*X4 - 0.125*X8 - 0.125*X10
Answer4 =
- 0.1847*X6 - 0.1306*X10
Answer5 =
- 0.1306*X2 - 0.1847*X4 - 0.1847*X10 - 0.00024049
Answer6 =
0.00024049 - 0.1306*X8 - 0.1847*X9 - 0.1847*X6
theta =
struct with fields:
X2: -0.00076274275732299026156747397808267
X4: -0.00031593839468454238506193227735856
X6: 0.00031593839468454238506193227735856
X8: 0.00076274275732299026156747397808267
X9: 0.00044680436263844787650554170072411
X10: -0.00044680436263844787650554170072411
What do you think??
Thanks so much for all your time an effort.
BA
x2 -5.294935592
x4 -6.311284333
x9 49.47392592
For the typical member, I considered K = 2EI/L to be 1.0, but for member 8, K would be 0.70711
On that basis, I find the following moments:
M2-1 = 0 - 2*x2 = 10.6kN=m
M2-4 = 0 - 2*x2 - x4 = 16.9
M2-9 = 0 - 0.7071(-2*x2 - x9) = -27.4kN-m ------- Sum = 0 (check)
M4-2 = 0 - (2*x4 +x2) = 17.9
M4-3 = 0 - 2*x4 = 12.6
M4-6 = 0 - (2*x4 +x6) = -x4 = 6.3
M4-9 = 0 - (2*x4 +x9) = -36.85 ------- Sum = 0 (check)
M9-2 = 0 - 0.70711(2*x9 + x2) = -66.22
M9-4 = 0 - (2*x9 + x4) = -92.64
M9-10 = 208.33 - (2*x9 + x10) = 208.33 - x9 = 158.85kN-m ------- Sum = 0 (check)
The sum of moments at Joints 2, 4 and 9 is zero as expected.
BA
I did not use your EI values, so had not noticed that your values seem a bit inconsistent. If actual rotations and deflections are required, the correct values are needed.
The following are the values you used:
E = 2e+08; a value of 200,000,000 (not the usual units); E for steel is normally taken as 200,000 MPa, which is the same as 200,000 N/mm2
I = 0.002; that seems very small. It should be given in consistent units.
EI = E.*I;
L1 = 5; this term is in meters.
q = 100; this term is in kN/m
FEM1 = q.*L1.^2./12; this results in units of kN-m
FEM2 = -FEM1;
It is advisable to maintain a consistent set of units throughout all calculations. If you don't, you tend to get very strange results. As mentioned earlier, for this problem, relative stiffness values are all that is required.
BA
As you can see this is correct
@Tygra,
After writing the above, I was unable to find the inverse of the matrix. I don't know what is wrong.
Update: Found the inverse, but the answers can't be right because x2, x4 and x9 do not equal -x8, -x6 and -x10 respectively, which they must because of symmetry. Looks like we'll both have to sleep on it.
Update #2: Found the error. Made a mistake in typing one of the cells. The answers agree with the results I found using only three nodes.
Rotations x2 through x10 are shown in column S of the table above. To get the correct rotation, multiply all values by 2EI/L.
BA
I believe I was mistaken about an error in your joint equations. So far as I can see, they are all okay. I am attaching the results of both sets of calculations (see below). In both sets of results, the original joint matrix is from columns C to H. Fixed end moments are in column J. The inverse matrices are from columns L to Q and the final values of rotations are in column S.
In both cases, x2 = -x8; x4 = -x6 and x9 = -x10.
The sum of Joint moments is zero for both results below. If you are getting different results from those that I show, the problem may lie in a misunderstanding or misapplication of your software.
BA results on Rows 2 to 7:
Tygra results on Rows 9 to 14:
Conclusion: there is nothing wrong with the equations in either set above. In both cases, the sum of moments at every joint is zero.
BA
Edit: just caught your edited post BAretired. Hoping you can save me from this torment tomorrow lol.
Edit2: I think we need someone that is exceptional in Matlab too.
So the way I described it is similar to how BAretired solved it.
FEM = [stiffness][rotation]
rotation = FEM\stiffness. I have attached the excel, sheet2 is the numerical expression. Try that and see if it works (kindly verify my units of E and I in the spreadsheet. Is this due tomorrow or it's a personal project? (I have an ideal but that we don't have time for that now, it involves writing a whole different script)
EDIT
If you break it down to Joint 2, Joint 4, Joint 6, Joint 8, Joint 9, and Joint 10 you should get the same matrix as BAretired.
We did something similar using the stiffness matrix back in school but I can't share the script since I wasn't the only one who worked on it but I can share the idea later with you. I tried getting my friend to give me access to his MATLAB account since I no longer have the license but couldn't reach him. I'm planning to learn Python since it is free and try developing scripts for my designs as well.
I am really sorry I couldn't be of help at the moment. All I can say is BAretired got it correct in Excel.
In November there will be a coursework where we have to design a steel-framed building. The lecturer said we will need our knowledge from the previous modules of structural and stress analysis in year one and structural analysis in year 2. For this reason, I have been pratising with slope-defection equations that I learnt in structural analysis to prepare myself for the coursework. I might be wrong, but I think the structure for the coursework might be more complicated than the example we have been working on.
That is absolutely fine. I thank you and BAretired for your patience and all your help thus far. I have decided to adopt your method, but I thought I would have a go at solving a smaller structure. However, I am not getting the correct rotations. Could you check my workings to see where I have gone wrong, NicOkai?
Here is the structure with its answers.
https://res.cloudinary.com/engineering-com/image/upload/v1634570812/tips/Stiffness_method_wilfbz.pdf
This is my Excel matrix
This is the Matlab code with the rotations I am getting using.
A = [800000 0 400000 0 0
400000 0 800000 0 0
0 1300000 650000 0 0
0 650000 1300000 0 0
0 0 1300000 650000 0
0 0 650000 1300000 0
0 0 0 665640.2355 332820.1177
0 0 0 332820.1177 665640.2355]
B = [0
0
0
0
166.6666667
-166.6666667
0
0
Y = pinv(A)*B
1.0e-03 *
-0.0779
-0.0779
0.0974
-0.1180
0.0944
You have to solve two equations, one for Joint 3 and one for Joint 4. The other joints are all fixed.
BA
Only Joint 3 and 4 can rotate. Also I think MATLAB "pinv" gives "different" solution" as it's a pseudo inverse. Try using "pinv", "inv" and "/" to solve an inverse of matrix you know the solution and watch the results you get.
m1i = 0.8e+6, m1j = m1i./2
m2i = 1.3e+6, m2j = m2i./2
m4i = (2e+8.*0.006)./sqrt(4.^2+6.^2), m4j = m4i./2
FEM1 = 166.667
FEM2 = -166.667
syms X1 X2 X3 X4 X5
X1 = 0; X2 = 0; X5 = 0
M1i = m1i.*X1 + m1j.*X3
M1j = m1j.*X1 + m1i.*X3
M2i = m2i.*X2 + m2j.*X3
M2j = m2j.*X2 + m2i.*X3
M3i = vpa(m2i.*X3 + m2j.*X4 + FEM1,5)
M3j = vpa(m2j.*X3 + m2i.*X4 + FEM2,5)
M4i = vpa(m4i.*X4 + m4j.*X5,5)
M4j = vpa(m4j.*X4 + m4i.*X5,5)
joint3 = vpa(M1j + M2j + M3i,5)
Joint4 = vpa(M3j + M4i,5)
y1 = equationsToMatrix(joint3)
y2 = equationsToMatrix(Joint4)
A = [y1; y2]
B = [FEM1; FEM2]
Theta = inv(A)*B
X3 = Theta(1) = 0.000077298482151272739116422631226081
X4 = Theta(2) = 0.00014791975279127278677572495087085
3.4e+6.*X3 + 650000.*X4 + 166.67 = 333.33700000000000159161572810262
Column 1:
Slope-deflection equations
Fixed end moment = 125(4^2)/12 = 166.67kN-m
Joint 3: θ3(k1+k2+k3) + θ4(k3/2) = 166.67
θ4 = -107.82
θ3 = [166.67 - (-107.82*0.65)]/3.40 = 69.63
BA
Question (d)
Moment in Beam 2 is -0.65*θ3 = -45.26kN-m and -1.3*θ3 = -90.52kN-m left and right respectively.
Question (e)
member 3: Msimple = wl^2/8 = 250kN-m
m3 left = 166.67 - k3(θ3 + θ4/2) = 146.23
m3 right = -166.67 - k3(θ3/2 + θ4) = -71.76
m3 midspan = 250 - (141.0 + 94.90)/2 = 141.0kN-m
BA
How about an update? Was any of the above helpful?
BA
Yes, I have solved both problems now, although the smaller problem does have me scratching my head a bit. This is because I have attained the answers that in the handout (the yellow sheet I previously attached), but strangely my joint equations doesn't equal zero. See the image below:
For the larger problem my joint equations don't equal zero exactly, but they are a very small number close to zero - like 7.3e-39. Do you think this could well be the correct answers? The rotations match the symmetrical geometry of the structure too.
BA
What do you think about the smaller problem? I am getting the correct rotations of X3 = -6.96e+5 and X4 = 1.08e+4, but my joint equation equals 166.67?
If you find it useful, that's fine, but I think it is better to understand what the program is doing. Converting linear equations into matrix form is pretty straightforward. Here is one article which explains it: https://www.varsitytutors.com/hotmath/hotmath_help....
I believe you are forgetting the slope-deflection formula. Following is the formula you posted earlier in the thread:
Your sign convention indicates that clockwise rotation is negative, counter-clockwise positive, but you must include the FEM in the beam moment. If you do that, the sum of beam moments at each joint is zero.
BA
You are right, changing linear equations to matrix form is easy. But for my larger structure it would be quite tedious putting the values into the matrix. So, for an even larger structures the equationsTomatrix function is very, very handy.
Thanks for all your help BAretired.
BA
I think Tygra is from Europe or UK. Remember to keep your signs and units consistent throughout the calculations. Wishing you all the best on your project!
https://mwi.solutions/technologies/wms-wcs-and-oms...
