mikealpha88
Hello fellow engineers.
I have an interesting question for engineers who may be designing screw piles.
In one of the recent projects, screw piles were nominated to manufacturers specifications. The piles were supposed to be designed/installed to support 300 kN SWL.
After installation I have been provided with the below details from the piling contractor.
Shaft dia 168.3mm x 4.8mm walls
Single helix 16mm thick, 500mm dia
Depths of each pile to reach 3500 PSI pressure.
Usually, there is a torque reading and then Kt factor to multiply to torque reading to get the ultimate capacity of the pile. However, I have been provided with pressure reading.
If someone can please help me understand that if this pressure reading is the for the hydraulic fluid from the torque/pressure gauge or actual ultimate capacity of the pile in PSI?
