Quick and dirty strain relief for a wire soldered to a PCB
Hi all,
I have a stranded wire soldered to a PCB, 22swg or thereabouts. The wire is likely to see a limited amount of moving around, because it is attached to a battery cover, so everytime the product's batteries are changed (maybe once every 6 months), the wire is going to get wiggled about. I'd like to put a bit of strain relief on it - but I'm wondering if anyone has any suggestions for a dirt-cheap strain relief option, suitable for manufacture, just to protect the soldered joint? At the moment I'm thinking hot-melt, but having a nice leaky hot glue gun in an assembly environment is not ideal. Black tack would be convenient, except it stays sticky. Bootleg ferrules are also an option, but that's more time and cost...
any tricks of the trade?
thanks,
Matt
thanks,
Matt
RE: Quick and dirty strain relief for a wire soldered to a PCB
TTFN (ta ta for now)
Dan - Owner
http://www.Hi-TecDesigns.com
Keith Cress
I've also learned the phrase "glob top" ;). For now I've gone with hot melt, but thanks to you all I've got a few more options to consider.
Cheers!
Keith Cress
use an RTV type of glue. make sure there is some RTV attached to the wire insulation AND the circuit board, or whatever you are soldering this wire too.
then, just as important, make sure the wire has some stress relief in it. you do not want it taut, as thermal contraction will then pull the RTV off the board.
Flexible copper wires can flex millions of times. but flexin that same wire right at a solder or crimp connection will work harden the copper metal and it will fail.
if this is a high vibration application, also make sure that wire is tied down along its length periodically too, so it does not resonate and tear itself off
