hokie66
- Jul 19, 2006
- 23,206
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
timeforchill said:it was much hotter on 9/25 than prior days, peak temperature right when they derailed.
1503-44 said:84°F is relative. Installation temperature might not have been 20°C 68F
NTSB Website said:Due to the possible complexity of railroad accidents and the extensive nature of the investigation process, a railroad accident investigation often requires 12 to 24 months to complete. Depending on the circumstances of the accident, the IIC along with other NTSB investigators and party members may travel to the accident site to collect information. The NTSB has the authority to designate organizations, corporations, or agencies as parties to the investigation. Only representatives who can provide technical or specialized expertise are permitted to serve as a party member and report directly to the NTSB. The NTSB will not determine the cause of an accident while on scene.
The following are reports and products that can be issued during the investigation:
The preliminary report provides a synopsis of factual information collected during the on-scene phase of the investigation. This report is typically available a few weeks after the accident.
The final report provides a summary of relevant factual information, analysis, findings, probable cause, and safety recommendations issued or reiterated as a result of the investigation.
An accident brief consists of a short accident narrative, probable cause, and if issued, safety recommendations. Briefs are normally limited to factual information but may contain analysis.
The report or brief replaces the preliminary report and is typically available 12 to 24 months following the accident.
You can access NTSB reports by searching the NTSB’s Case Analysis and Reporting Online Search (CAROL).
An accident docket contains relevant factual information collected during an accident investigation that is used in the development of reports, briefs, and safety recommendations. The docket is available to access at an appropriate time during the investigation, or at its conclusion.
Many investigations result in safety recommendations or safety alerts. The NTSB can issue these at any time during the investigation process.
