Constructability vs. Constructibility
I've seen both used. Both are in the dictionary. They seem interchangeable. Very subtle difference in spelling.
Is one more correct than the other for a particular application?
My thought is that Constructability is probably more correct since it contains "ability", or able to be constructed.
What does "ibility" imply?
Just pure curiosity on my part.
RE: Constructability vs. Constructibility
TTFN (ta ta for now)
It's pronounced potato tomato.
Andrew H.
www.MotoTribology.com
Haha, I like it.
Constructability seems natural to me for engineering contexts and is featured prominently in wiki on constructability
Constructible / constructibility seems to be in common use by the mathematicians as shown here
So I get the feeling constructability is a practical review of challenges that will be encountered during construction....
whereas constructible / constructibility is a theoretical concept related to whether it is even possible to construct something.
But I see on the interwebs there doesn't seem any agreement on definitions... so I guess that means it's impossible to be wrong (?)
(2B)+(2B)' ?
https://www.thefreedictionary.com/Commonly-Confuse...
They do say that:
"there are generally no indications in the base word’s spelling to indicate when “-ible” is correct, except for one: base words ending in “-uct” will (almost) always take “-ible” rather than “-able.”
so I'll go with "constructible".
http://julianh72.blogspot.com
Let's look at other words ending in *uctible/*uctable
- Deductible sounds very natural to me (I'd never spell it deductable). But the concept of deductibility is also a go/no-go thing (just like the mathematical uses of constructible) rather than an evaluation of the practical difficulty of doing something (like constructable).
- Indestructible. Hmmm I guess we could make the argument that's also a go/no-go, although not as strongly as deductible.
- I can't think of many other *uctable words
I realize at our plant we have a formal process which we always call "constructability review" (it's described in a procedure, that's the way the procedure spells it, so that's naturally the way everyone at our plant spells it). So my personal perceptions are undoubtedly affected by seeing it spelled that way so many times over the decades I've worked there.But I think we're not the only ones. I think it is much more common for others to spell constructability review with an a, based on poking around google:
- If you google the two words constructibility review (with an i), google will suggest constructability review (with an a)
- If you accept their suggestion constructability review with an a, the vast majority are spelled with an a.
- If you insist on searching constructability review with an i you'll get more with an i up fron but intermixed with a...and the a's win by a landslide as you go back further into the results on the 2nd and 3rd page (google could only find a handful spelled with an i, and so google put them all on the first page)
=====================================(2B)+(2B)' ?
I hadn't heard that, but googling led to this:
Like everything in our quirky English language, it's complicated.
Can we draw a conclusion about constructable/ible from the latin/non-latin origin?
- IF our word of interest were not of latin origin THEN we could draw a definitive conclusion that it ends in able.
- Unfortunately construct is a word of latin origin (constructus)....con (together... same root word as consolidate) struct (pile/assemble...same root word as structure)
- For words of latin origin we can't draw a conclusion from above.... some are able and some are ible
- So the answer is no.
Can we draw a conclusion about constructable/ible from the thumbrule?- The thumbule suggests since we can remove the able/ible and end up with a complete word, it should be able.
- But the thumbrule says there are exceptions.
- So again the answer is no.
it's much more complicated !!
https://www.merriam-webster.com/dictionary/constru...
