SWx 2019 with SmarTeam Editor V5-6R2018 modified components issue
sshhehab
1
Hello there,
Background info:
Company was using SWx 2015 till last year, this year we upgraded to SWx 2019 (last version that supports SmarTeam), we migrated the most of the files in the vault of SmarTeam to support SWx 2019 as well.
current issue: whenever an assembly is opened in Solidworks with SmarTeam integration is on, a window is shown (attached picture) saying “Solidworks assembly" has been modified. Click here, or run "Modified components" command to repair."
SolidWorks is usually unusable as long as this warning is showing.
when modified components is checked, all files shown are read-only and released in smarteam and they weren't modified. any idea how to block this message or fix it? Mainly I think SmarTeam is checking some modification date on the locally saved file and the one in the vault and finding a difference and that's why it's showing this message.
 https://files.engineering.com/getfile.aspx?folder=dafc04ac-b02e-4b4e-870a-f1cfc7dbd4a4&file=error_ST_SWx.PNG
sshhehab,
Are you saying that you upgraded your files to SW2019? That is a modification, is it not? I want my CAD to support old versions just so I don't have to force upgrades. I am not a SmarTeam expert, but it sounds like it is comparing its change history with the time stamp on your file.
JHG
