Application of full autoclave pressure on epoxy prepregs BEFORE temperature ramp up
Im reading through Campbells Manufacrturing Processes for High Performace Composites and notice a section about some manufacturers applying full pressure before the cure cycle begins. Basiucally you load the tool in the autoclave and apply vacuum and full pressure, then start heating up. Apparently this is a way to process various composites with different requirements in one autoclave. I dont really have a need to do this but Im curious if anyone has done this and how it worked out.
RE: Application of full autoclave pressure on epoxy prepregs BEFORE temperature ramp up
The reason for not applying pressure until after heating is to allow the volatiles in the resin to expand the residual air in the prepreg and cause it to percolate out to the vacuum, before compaction pressure is applied. Many think of the compaction pressure as squeezing air out of the laminate. However, it simultaneously compacts the laminate and pinches-off the the paths through which air can be removed. Volatiles expand by changing from liquid to vapor state and will provide orders of magnitude greater expansion than simply heating air. This is very effective at removing residual air. Then when pressure is applied, the remaining volatiles (with no air) can be condensed and dissolved into the resin.
