Tubing material
Tubing material
Hi All,
I'm looking for a nylon tube which is food grade approved and it should withstand upto 25bar water pressure.
I want to use the pipe for drinking water applications. Maximum operating pressure is 25bar.
Tube OD: 8mm
ID : 5 - 6mm
Pls suggest any suite tube material wit its make.
Thanks in advance.
Tube OD: 8mm
ID : 5 - 6mm
Thanks in advance.
RE: Tubing material
What are your flexibility and temperature requirements?
RE: Tubing material
RE: Tubing material
I'm looking for atleast 16 bar
RE: Tubing material
these guys sell HDPE 16 bar pipe.
RE: Tubing material
RE: Tubing material
RE: Tubing material
Link
RE: Tubing material
Flexibility: the more will more better.
Temperature: 25 to 40 degree celcius.
Hello LittleInch,
Yes. we can go with copper. But we prefer plastic/rubber tube because of less price than Copper tubes.
RE: Tubing material
But it is very costly.
RE: Tubing material
If you want higher pressure then it gets more expensive than stainless steel or copper.
You can buy UHMW PE pipe which will do 25 bar I think.
https://www.duratecceramic.com/ultrahigh-molecular...
RE: Tubing material
Yeah. Food grade tubes with higher pressure capacity are very expensive than stainless steel or copper.
I'll check for copper tube price, if that fits our pocket.
Thanks for all your support and knowledge sharing.
