Finned pipe - Approximate thermal calculator
mrtangent2
Chemical
GB
I'm after some short advice here or a decent rule of thumb calculator to approximate the potential to cool about 1.5 te/hr in 1 inch pipe from around 200 to 60 C in finned pipe.
Its a basic oil fluid.
From a quick google search typical HTC id assume would be 500 w/m2 K, but I need a rough area to approximate.
looking for a calculator - doesnt seem like its in aspen / EDR..
thanks in advance
J
thanks, unfortunately it needs fan..
but a nice excel file .
Hi ,
I did some calculation and find a heat transfer coefficient 10 time lower than what you wrote in your post .
Properties of the inside fluid are those for Duratherm LT @ 250C and for the outside those for air @ 10C with a velocity of 5 m/s .
results :
U 53.842 w/m2 K
Q loss 2.37E+05 W
1139.7 w/m
Tout 60.4 C
I believe this is not workable using a finned single pipe .
Good luck
Pierre
