Tubing pressure reducing regulator
I need to blanket the oil covers on a compressor with nitrogen. The nitrogen is delivered to the skid in a 1" pipe at a pressure of 6 barg. The pressure shall be reduced to 1,4 barg. My intention is to put a piping to tubing adapter and continue with tubing lines within the skid.
My concern is that I expect basically NO flow since the only consumption point is the compressor shaft seal which has a rated leakage of 1*10^-4 cc/sec, meaning basically 0 liter/hour.
Will a simple pressure reducing regulator from the Swagelok K series work when there is no flow? Meaning, will the regulator maintain a constant pressure on the low side when basically no nitrogen is being consumed?
For example, I am thinking that it would not work with an orifice since the NO flow would settled out the pressure to be same on both sides of the orifice?
I believe the regulator will do the job but looking forward to some feedback or alternative solutions.
Here is a PDF with some more details of the regulator in mind https://www.google.com/url?sa=t&source=web&...
RE: Tubing pressure reducing regulator
You'll want to choose a diaphragm sensed regulator with as small a Cv as possible for this application to ensure maximum sensitivity and tight control of the outlet set pressure.
