Contact US
Air Flooding System
Air Flooding System
Air Flooding System
May I have some advices on air flooding system. Assume I have to design an air flooding system, e.g. a pressurized raised floor, how to estimate the air pressure drop of this flooding system in order to size the external static pressure of the AHU ?
Thanks.
RE: Air Flooding System
Could you provide more details on the system? What are the project requirements? The external static pressure is calculated by adding up the pressure drops of the air's pathway. What does the pathway look like for the air from start to finish?
@nuuvox000
Basically I'd like to understand how to determine the pressure drop of the air path if a flooding system is used, e.g. a pressurized raised floor system with the AHU just immediately connected to it with air outlets at various locations. I see such kind of raised floor design normally requires 50Pa ESP or even less, so want to understand how it's calculated
Yu mean under-floor air distribution? In general they are like plenums with almost no pressure drop. I'd start reading manufacturer design guides.
Unfortunately often the floor is too low, and many obstructions due to conduit, pipes etc.
What are you cooling? Is this for a data room? If so, then you'll typically have certain floor grilles to make the air come up in the correct locations. These grilles have manufacturer data that tell you pressure drop for specific CFM for FPM. If it's not for a data room then you'll need to provide more details on the project to get better answers. I don't specify any equipment with an ESP that low because of unknowns. For a data room especially I wouldn't specify anything under 0.5 in w.c. but the actual ESP depends on a lot of factors.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
