TIA PORTAL V13
TIA PORTAL V13
Hello guys,
could you please guide me to remove TIA PORTAL V13 Completely from my pc ,
i uninstalled it through the control panel, but it still exist within the programs.
thanks in advance
thanks in advance
RE: TIA PORTAL V13
You can just delete the leftover folder if that's what you mean. If you mean that it's still running, then you probably need to use Task Manager to find the location of the file, kill the process, and delete that folder. Bear in mind that other programs might also be using any shared process.
TTFN (ta ta for now)
RE: TIA PORTAL V13
is there any suggetion please ?
thanks in advance
RE: TIA PORTAL V13
RE: TIA PORTAL V13
