Getting Model Info from Patran Database .db
I received a random selection of analysis files from a recently departed colleague and I am trying to play forensic scientist to uncover what that status of the analysis was. Most of the analysis was done in Nastran which I have had no issues accessing in FEMAP. Some of the models were run in Patran which I am not as familiar with. For the models where I have a .bdf there's been issue as the file structure is nearly identical.
Several of the models there is only a .db database file however. Does this file contain the model information such as grid locations and elements/properties? Or is this just a result file? Can FEMAP import this file format?
RE: Getting Model Info from Patran Database .db
DG
DG
