overall drawing format issue, doesn't use the standard I set.
KirbyWan
Aerospace
Apr 18, 2008
586
Howdy all,
Using Solidworks 2021 SP3.0, but this has been an issue in previous releases as well.
I have the drawing standard set as ANSI in the document properties. But it uses ISO (I think). If I switch to any other standard and apply the changes then switch back to ANSI, it then uses ANSI. But every drawing I need to switch away and then switch back for ANSI to be the overall standard used even though it's what's the default. Is this a known problem? Can anyone suggest a fix. It's a minor annoyance, that bugs me a bit more every time I need to do it.
Thanks all,
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Create your template drawing. Change settings as needed. Then "File, Save Sheet Format", then save as file type "Drawing Template (*.drwdot)".
Go to System Options, change "Default Templates" and "File Locations" folder locations.
ctopher, CSWP
SolidWorks '17
ctophers home
SolidWorks Legion
