How to measure unloading time in Ansys?
Hello Dears.
I have an elastic shell model which has been folded through a quasi-static analysis by Ansys structural. The behavior is nonlinear, so large deflection is set on and loads are applied gradually. There are two steps. The first one is the load step and the second is unloading step, so the model return to its initial shape at the end. The problem is that, I don't know how to measure exact duration for unloading.In other words, I want to know how long does it take that the geometry back to its initial shape after unloading. In the static structural I have to define step end time by myself, for instance 1s, while in experiments it may take 0.5s or lesser.
Would you please help me?
Thank you so much.
Thank you so much.
RE: How to measure unloading time in Ansys?
You need to solve transient nonlinear problem. In thansient time is real physical time.
