Hi experts, this is my first post here.
My previous experiences are limited only for onshore pipelines and always utilize HSS for FJC.
We are currently doing FEED for offshore pipeline and I have below options to select from client specifications for offshore pipeline FJC.
I have done some preliminary research, but still hard to choose the most fit-for-purpose one (integrity, cost, ease of application), hope you experts can give more input from field experiences.
1. Non-crystalline low viscosity polyolefin tapes with polymeric tape outer wrap
This looks easy to apply and doesn't require heating, but I don't know if tape wrapping will give high integrity in subsea
2. Liquid epoxy or derivatives
This also looks easy to apply, but long curing time may disturb whole pipelaying process.
3. Liquid polyurethanes per derivatives
Similar issue with liquid epoxy
4. Flame sprayed polyethylene powder applied over an epoxy layer
Good high integrity FJC, but likely tough to be applied offshore as this require specialized machinery to heat and spray
5. Polyethylene tapes/sheets hot applied over an epoxy primer
Similar issue with polymeric tape wrap, and require additional heating equipment
