determine longest flow path for large basin using ArcGIS
Do any of you know any good plugin or tools for ArcGIS to determine longest flow path for a large basin (500 square miles)?
I tried ArcHydro, which is not reliable? also tried Miscellaneous Hydrology Tools for ArcGIS (https://www.arcgis.com/home/item.html?id=fc7c1ca07...), but is not working for me. I am using ArcMap 10.8.1 with Spatial Analysis extension. Does anybody knows the other tools that will solve the longest flow path problem? Thanks in advance.
RE: determine longest flow path for large basin using ArcGIS
