How to set non-linear spring rate in MSC Adams (eg Bushing) through force-displacement?
karachun
UA
Good day,
we have at our disposal data on the stiffness of a three-dimensional spring in a tabular form "force-displacement" (in three directions). We need to set the spring rate through this data.
An example of the data is hovered below.
Force, N Displacement, mm
-3500 -35
-2000 -15
0 0
2000 20
3500 40
How can you set the non-linear spring rate (eg Bushing) through force-displacement?
Thanks in advance!
Hello Greg.
I want to create NL Bushing in View module.
I don't use View, so this is a bit of a guess
Create a spline for your data
create a bushing
in the K field right click and select parametize
then build an expression using the spline you've already created.
There's a section in help called Example of Using Splines which goes through the process for a spring.
Messy.
Cheers
Greg Locock
Greg, thank you for response.
