Get unitVector X Y Z values
Hi all
i want to create lines on a surface using bunch of points, those lines must be in 5deg incremental
here are the steps
Step:1 - first i will create lines using normal to surface option
Step:2 - then i measure the angle between normaltosurface line and xyPlane if the angle is near to 5deg mutiples number for ex if angle is 81.23deg
Step:3 - then i should create a line using point-direction option which is 80deg and if angle more than 82.5 and less than 87.5 then i should create a line using point-direction option which is 85deg
i need to get the X Y Z direction components which makes the angle between point-direction line and xyplane 5deg multiples like 80,85,90,95,100deg
the surface in the image is not actual surface
x y z components are unit vectors of line that i need to create
i know the angle, for that angle i need to find out the X Y Z unit vector values using VECTOR ROTATION IN 3D SPACE FORMULA
here is the image of that formula
here we know the value of theta using that we need to calculate X Y Z unit vector values
i need to this in VBA
thanks
here are the steps
thanks
RE: Get unitVector X Y Z values
so you have a point A on surface, a Line L, and the angle Theta with Z direction.
This angle is in the plane P defined by L and the vertical line V passing by A.
create the vertical line V and the plane P using vba
the rotation angle Theta could be measured between L and V. the rotation axis would be a line R normal to P passing by A
create this line R in vba
using the reference line V, the line axis R, and angle Theta, you can create the line L2 you want using line angle (ref plane is P and angle is Theta2...)
Create this line L2 in vba
use VBA to measure the line and get its direction, that will give you the XYZ value of the vector of the line you're looking for.
now you can build the line in vba with the point A and the direction you have.
i am not getting the following statement
what is vertical line V here and plane P
could you elaborate please
you measuring your normal line L and the vertical Z.... Z is a direction not a line so I say you create line passing by point (A) on surface with vertical direction (line v)
the point (A) is the point on the surface where the normal line start from
the plane (P) pass by your normal line (L) and a vertical line (V) from point (A) on surface
