Export Part of and Assembly from 3DX
Hi all,
I'm brand new to 3DX (coming from many years in NX) and I have to believe there is a way to export only the part of an assembly desired.
Any help will be most appreciated!
-Wulfgang
-Wulfgang
RE: Export Part of and Assembly from 3DX
If you are exporting using Catia V5 Files, it seems that Exclude is not available. However, if you first Unload the models you don't want exported, then the export appears to run using only what you have open in session. Same for STEP. Right-click in the Tree and click on 'Unload.'
A note on the Unload functionality: This will drop models out of your session, but does not alter the product structure. It will appear the same as if the child part was deleted, but it is not deleted at all. If you re-open the parent assembly, everything will be reloaded again. (Search your product and Open it again; you do not need to close your product first) There are some times where this is very handy.
-Mark
What does it mean "part of an assembly desired"? A node? Some specific selection?
More details, please.
Fernando
https://www.youtube.com/playlist?list=PL9mSHa4SOed...
Thanks for the response. I saw the Unload option but wasn't sure what that would do to the assembly. Sounds like it would do exactly what I want, thank you!
