Good morning every once.
Presently I am working on Cv calculation of Valves with different shape of valve trim, if I change shape of stem trims Cv valve also changing.
For example in Quick opening amount of fluid discharge between seat and trim are more compare to Equal opening, please refer Figure 02.
If this statement is true then 100 % open condition the Cv valve won’t be same for Quick, Linear and Equal condition.
For example (100% open condition)
Quick valve (Cv value) = 2809
Linear valve (Cv value) =2600
Equal valve (Cv value) = 1150
Pease conform me whether this Cv valves and graph (figure 03) are correct or not.
Senthil Ramajayam
Senthil Ramajayam
