Moldex3D: I need help with Moldex3D commands
andradesilva
Materials
PT
I am using Moldex3D for the simulation of the injection moulding process. I did the simulation, but I need to know the commands of the following tasks:
1) Importing an external geometry
2) Select all the lines of the imported geometry
3) Give the selection of 2), the attribute of "cooling channel" as in the "Model-Attribute" menu.
4) Select "check cooling system" (for automatic creation of a Moldbase and placement of water line inlets and outlets.
5) Command "specify face" and select the inlet face.
6) Mesh all the elements (piece + waterlines + moldbase), as within the "Mesh" menu.
I don't need anything too detailed. I just would like to know the commands, as I will search for them in the Moldex3D documentation and read about them and their syntax.
I thank you all in advance,
Best regards,
Andrade Silva
