Different between Gas Vs Liquid Pressure Transducer, can both be used fr same application Vice Versa
I am just wondering if this technology is the same.
1. Can we use gas pressure transducer to measure liquid ?
2. Reasons being, it is easier availanle and economical to find a BLE Pressure transducer for gas that has a featurez of data logging and alarm to measure vacuum to presure
Cirrussense
https://www.hydracheck.com/catalog/pressure-test-p...
Intend to get this from pressure direct to try to measurr liquid like water .
Anyone has any idea if can source this type of sensor and build our own wireless communication and interface.
Cirrussense
RE: Different between Gas Vs Liquid Pressure Transducer, can both be used fr same application Vice Versa
Brad Waybright
The more you know, the more you know you don't know.
I could not find any mention of materials of construction of the wetted parts, the material that the process is in contat with, which is what determines compatibility with gas or liquid. It's probably stainless steel, but there is no mention.
