temp sensor testing
temp sensor testing
In a temp sensor test certificate, what is last column 93.cms meaning? see attached
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: temp sensor testing
TTFN (ta ta for now)
- the D2401-2 trimode (triple mode) device is a level/interface and temperature measuring device
- one of the tools used is a tape/ruler with a traceability cert
- the units in that column are centimeters
then I would deduce that the measurement of an actual level at 93.0cm had an error of -0.3cm at a reported reading of 92.7cm.
Seems odd that they only tested one point for tape measure, maybe because the OP seems to think it's only a temp sensor
