Hello to All,
I am trying to remove a U-shaped sheet pile wall from the end of a dock with a Vibro hammer attached to a crane. The sheets are corroded. Also, there are a lot of vertical welds between the sheets. We removed all the wall elements, torch cut the weldings and did a lot of vibrations. The sheets are simply not moving or are moving just a few inches. Looking for somebody who has some experience with this type of situation. Thanks in advance for your help.
