Rakesh2560
Greetings All,
I am new in the field of valve selection and am looking for information related to selection of valve .We are looking to purchase a 24" , 300# Emergency isolation valve for one of our plant we have received offer from different vendors however i have a few questions The service is clean hydrocarbon non Nace
(1) For ball valves is bearing material SS 316 with PTFE coating acceptable ? i think we can select this upto 150 deg C but not sure where to find the reference for this ?
(2) For big size ball valves are sealant injection points for steam and the seat mandatory ?
(3) Most vendors are offering ball material as eg A350 LF2 + 75 m ENP + 150 m TCC ,A182 Gr F6A cl 2 , A217 CA 15 + TC , F6A + TCC i am not sure about A217 CA 15 and its performance in comparison to others any guidance about this will be helpful.
(3) Need information regarding 75 m ENP + 150 m TCC what does 75 micro m ENP +150 micro m TCC mean ?
(4) Can the ball material be same as the trim material ? Eg if ball is A350 LF2 + 75 m ENP + 150 m TCC then the trim material can be A350 LF2 + 75 m ENP + 150 m TCC ? I am confused as the same material will lead to no difference in hardness and with the time damage to both seat and the ball will ocurr i assume here ball should be more harder the seat as seat can be replaced when needed.
Thanks well in advance for all those who provides their valuable time and guidance for my post.
R
R
