Contact US
Designing for Impact
Hi folks, I'm working on designing something that will withstand impact from a heavy piece of equipment. I have no problem figuring out how much force the barricade can withstand.
My problem is that when trying to figure out the impact force that this barricade will feel varies wildly depending on the assumed duration of impact or distance (crumple zone) of impact. This isn't a situation where we can test anything, so an assumption is sort of my best bet. I used 0.1 seconds for time duration of impact based on some stuff I found through googling, but there doesn't really seem to be a standard.
Could someone point me in the right direction? First time poster so apologies if I've made mistakes with regards to rules.
RE: Designing for Impact
kinetic energy of impact = elastic(or plastic) energy of deformation
Time varies with stiffness of the impacted structures. dA/dK. This is where FEA shines.
This often comes up for discussion.
If you go to the structural engineering general forum and click search in the Top LEFT, this limits searches to that forum and search on "vehicle barrier" Lots of possible responses.
Or try this forum and do the same.
Velocity has a huge impact on the force as it is often a squared term, but yes, there are many ways to deal with this or you can assume a certain force like the highways people do.
I'm not sure there is a "standard" for this, only lots of assumed numbers. Only you can really determine whether those assumptions are correct in your situation and what you finite limits are, what level of deformation you can accept, whether this protection or a normal occurrence etc etc.
I always think you're better off with determining how much crumple you're going to accept and then working out from the speed of the thing impacting, how much time that takes and assume a steady force to decelerate the thing.
You can look at design of bollards or vehicle barriers perhaps for some guidance.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
