Existing Separators Gas Outlet Nozzle Nozzle Velocity Head
Dear All,
Based on GPSA for G/L and G/L/L separators, the velocity head at the gas outlet nozzle is typically limited to 4500-5400 Kg m/s2 in order to limit the channeling of the gas through the gas outlet internal. If the velocity head in downstream piping exceeds 30 m/s but is still within the NORSOK velocity head limits preventing erosion. In you opinion:
1- if the separator gas cap area is selected to fulfill the gas liquid separation requirements. what is the possible reason behind such limitation in velocity head other than gas channeling and vibration mechanical integrity issues on the gas outlet internals?
2- What could be the potential revamp measures to allow higher momentum in existing gas outlet nozzles than the above mentioned limits?
RE: Existing Separators Gas Outlet Nozzle Nozzle Velocity Head
Think in the coalescing process with is affected by turbulence created in high gas velocity inlet.. There are to process; oil drops going down in gas phase and gas bubbles going up into the oil phase.
Horacio
https://www.linkedin.com/company/lagotuy/
Consider this guideline, the answer is in your question .
The reason why standards have been established . At the end it's your decision.
https://www.red-bag.com/engineering-guides/249-bn-...
Good luck
Pierre
