Difficulty in running program
makyy
Automotive
JP
Hello Everyone,
I have one combobox which i populated with DefaultGenerativestyle and inheritance_3D.
Then I have a command button that selects views( front view, back view , left view, isometric view,etc) and populate listbox with the name of the view.
I crated one more command button named run on userform ...
What I want is when I select DefaultGenerativeStyle on combobox and select a view or two(front view, left view) then those view's View style should change to default generative view style when I click on run.
I know that I can use if function but it does not seem to work.
Any help will be appreciated.
Thankyou
show us the code
regards,
LWolf
Thankyou for replying...
For Combobox I used
Private Sub UserForm_Initialize()
With cmb_SelectStyle
.AddItem "DefaultGenerativeStyle"
.AddItem "Inheritance_3D"
.AddItem "R17_GraphicReplacement"
.AddItem "ShellExpCmd_DrwTemplate"
End With
cmb_SelectStyle.Value = "DefaultGenerativeStyle"
End Sub
To Select the View I used
Private Sub ViewSelect_Click()
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Dim InputObject(0)
InputObject(0) = "DrawingView"
Dim DrwSelect As Object
Set DrwSelect = CATIA.ActiveDocument.Selection
DrwSelect.Clear
Dim Status
Status = DrwSelect.SelectElement2(InputObject, "Select View", False)
For i = 1 To DrwSelect.Count
Dim DrwView
Set DrwView = DrwSelect.Item(i).Value
ListBox1.AddItem (DrwView.Name) 'To get the view in the Listbox1
DrwSelect.Clear
Next
End Sub
I want to use the run button to change the view style
I tried recording macro for the run button but its not working...
I have to use generative behavior it seems like..
Dim drawingViewGenerativeBehavior1 As DrawingViewGenerativeBehavior
Set drawingViewGenerativeBehavior1 = drawingView1.GenerativeBehavior
drawingViewGenerativeBehavior1.ForceUpdate
