Contact US
Acoustic signal generator
Hello everybody,
I'm currently testing St mems microphone and I'm trying to measure sound level pressure using a device that emits frequencies between 20Hz and 20Khz ( human hearing range). With that being said Can anyone recommand a device that generates acoustic signal.
Thanks in advance.
RE: Acoustic signal generator
You mean reliably, over that range, with a flat frequency response? Good luck. 20 Hz implies a speaker several metres across, 20 kHz half an inch. I suspect the usual way is to put an instrumentation quality mic into the same soundfield and compare.
There may be a reciprocity rig that would work, never seen one.
Cheers
Greg Locock
Actually I found one device with a speaker that reads wav files from sd card and generates the corresponding signal. But I'm looking if there are other devices and other options
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
