Contact US
Minimum Crane Stability Design Code
Greetings,
I'm trying to find the code that has the Minimum Crane Stability. The only information I have is that it's from a Technical Specification Section 4.4 and I can't seem to find it. The reason I'm looking for this code is because I'm trying to see if the Lifted Load (LL) and Stall Torque Load (STL) are calculated together when doing the stability calculation. From one of the previous jobs that I did, STL wasn't calculated with the LL and I just wanted some clarification on this.
RE: Minimum Crane Stability Design Code
fzlo,
Please provide additional information on exactly what your question or problem is. I don't understand what your question is. Include where you are designing this crane will be used and what code you are designing with. Also include what kind of crane you are using.
Jim
Hi Jim,
It's a ship-to-shore container crane that we will be using at Fernandina Beach. The codes we were using are ASD 14th edition by AISC, FEM 1.001 3rd edition, CMAA Specification #70. I'm just trying to find the right load case for the stability report. We have it listed as dead load + trolley load + lift system + lifted load + Operating wind + Stall Torque Load but I wasn't sure if Lifted Load needs to be in that load combination.
fzlo,
I have never designed a container crane, so I am unfamiliar with specific requirements, however I can not imagine not including the lifted weight in stability calculations.
Jim
Isn't the lifted load the whole point? Is there an impact load also someplace? It's been a long time since I've messed with cranes of any kind.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
