Pianomoves
Student
Looking to design this Ramp to move pianos so it is lighter weight than the current design as I have an aluminium welder available.
Currently beams are steel Square SHS 25 x 25 with 18mm marine ply ontop.
Would you have any suggestions on changing from steel to aluminium frame and the plywood exchanged for some sort of aluminium top etc. Or even a whole new design.
Here are some pictures of the current design and dimensions of the ramp The max weight of any piano moved will be 600kg distributed over the four wheels. 99% of any of my piano moves will be around 250kg
Grateful for any suggestions/advice
