Contact US
Servo Motors Rated Speed
Hi Everyone,
What is the difference between "Rated speed nC(1/min)" and "output speed" in servo motors.
At the same time While "rated motor speed" is 1405(1/min) in gearbox catalogue, Rated speed is 3000 (1/min) in servo motor catalogue for the same gearbox.
If someone has a knowledge about this kind of servo motor and gearbox, can you inform to me.
Thanks in advance
RE: Servo Motors Rated Speed
I would think that nC 1405 (1/min) is "max" speed at max torque, while nN 3000(1/min) is max speed for motor continuous with "medium" torque.
IC [A] - maximum short-time permissible current (r.m.s. value) which is given by the intersection of current limitation of the servomotor and of limitation by the rated voltage of the converter – LIMITING POINT C; mostly IC is identical with the highest permissible servomotor current (Imax.)
MC [Nm]- maximum torque of the servomotor at the current IC and speed nC
nC [min] - speed of the servomotor at IC and MC
MN [Nm] - rated torque - continuous torque on the servomotor shaft at nN and UN for continuous running duty S1 (defined for temperature rise of the winding 105 K and for the rated value of KE)
IN [A] - rated current - r.m.s. value of the servomotor current for MN and nN
nN [min-1] - rated servomotor speed
http://servo-vsm.eu/file/2520/EN_SERVO%20INFO_0209...
Best regards A
Albert Einstein
Thank you for repyling to me.
You are welcome Anna
Albert Einstein
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
