  • Congratulations IRstuff on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Stitch Weld Symbol
efFeb
68
Good Morning,
I'm sorry if this is an obvious question, but I have received drawings with a stitch weld symbol indicating "12" EACH END".
This is for a detail with a WT welded to the bottom of an existing W section for reinforcement.
I am expecting that this means a 12" continuous weld each end, but could anyone confirm that this is the case?
Thanks so much in advance.
That would be my interpretation, but I didn't draw it so take it with a grain of salt. You said you received them...are you working for a fabricator? If so, send an RFI to the EOR for clarification.
Definitely means 12" at each end before starting the stitch weld. Very common, I would never question a note like that.
I use that designation often... any end plate?
