Contact US
Threaded insert spacing
Dear All,
Here is my case.. I have a camera housing (rectangular box made of steel) bolted to a bigger structure. So far I am using M12 DIN912 bolts made of INCONEL 712 and to increase the strength of the 'female' thread I'm using M18 (external thread) inserts. This is a tapped bolted connection.
My question is, is the bolt spacing 3 x bolt diameter or 3 x insert diameter (M18)? It is not very clear to me so I would appreciate your help!
Thanks a lot!
Ezequiel
RE: Threaded insert spacing
I would go with 3 x the insert diameter since the issue is the distance between the O.D. of the threaded holes, not necessarily the distance between the sides of the bolts.
John R. Baker, P.E. (ret)
EX-'Product Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Ezequiel1982
a sketch with dimensions would be much clearer
Must be one heavy camera if you need to use very expensive inconel bolts.
Yes, add a sketch.
Dear All,
Thanks for your comments! It is not a heavy camera but it is subjected to very high electromagnetic forces. This way I am using INCONEL. Furthermore, due to lack of space I can't increase the size of the bolts.
As far as I could read the distance 3 x bolt diameter is to avoid bolt's pressure cone interfere with each other because if that happens then the stresses will be too high and the component may fail. If it is true, then the driven dimension is the bolt head diameter and not the insert diameter.
What do you think?
cheers!
Ezequiel
No, the load is being transferred through the inserts, their OD is the governing dimension.
Could you get away with 2.5x? Likely, but you do risk causing distortion of the mating face.
If there is so much EMF involved why is the box steel?
Can you get hardware in Nitronic 50?
Ezequiel1982,
Why so many bolts? Are you trying to seal the thing?
JHG
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
