Connection Error - Ram API
rscassar
AU
Has anyone been getting a connection error when using the RamConcept API
ConnectionError: HTTPConnectionPool(host='localhost', port=50795): Max retries exceeded with url: / (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x0000023BFCB03AF0>: Failed to establish a new connection: [WinError 10048] Only one usage of each socket address (protocol/network address/port) is normally permitted'))
Here are some thoughts:
• Firewall is preventing messages from getting through.
• Concept is prevented from starting up? (you should be able to check that with TaskManager)
You can also try:
• Setting start_timeout_seconds in Concept.start_concept().
• Setting log_file_path in Concept.start_concept() to see what is happening on Concept.exe side
Thanks Seth, the problem seemed to go away. Was only happening yesterday, when I got to approx 15,000 pings I was getting OSError and NetworkError. I tried again this morning and back to normal. I was extracting all slab elements data from the model.
I believe the error came about cause I had two ram models open thru the API and that was giving some issues.
