Contact US
Why is there a magnet sleeve on the armature assembly shaft?
I need to purchase a quantity of routers and in inspecting some I noticed that the name brand router has a magnet sleeve on the armature assembly shaft, while some of the cheaper clones do not have the magnet sleeve. What is the purpose of the magnet sleeve? It is only mildly magnetic, and sits inside the plastic motor housings. It's item #18 on the parts blowup. Other pic shows one with and without the magnet sleeve.
RE: Why is there a magnet sleeve on the armature assembly shaft?
As a guess it may be a tachometer. It looks as though there may be some type of sensor mounted adjacent to the magnet.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
Hello Bill - Part #3 is a speed controller but I figured it was controlled by the speed adjustment pot that connects to it. Maybe the magnet does serve some purpose in regulating the speed. I spoke with tech support and they didn't know the function of that part...
It is probably a speed feedback device. A crude tacho-generator.
It will help keep the speed steadier under varying loads.
Or it may be something else.
Bill
Ohm's law
It's the LAW!
There are two ways they do speed control on hand power tools; it’s either a phase angle control using a triac, or PWM. The PWM has some advantages in efficiency, accuracy and quieter sound but needs a speed feedback loop. That’s likely the difference; the more expensive one uses a PWM controller so it has that magnetic sensor as a speed feedback.
Ok, that makes sense. Thanks everyone!
Thanks Jeff.
Bill
Ohm's law
It's the LAW!
It is of some interest to see where the poles are.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
