Contact US
Difference Between Lock-In Amplifiers and other Coherence methods
Hello, I was wondering if somebody could explain to me the difference between using a lock-in amplifier and other signal coherence methods such as MSC. From my experience MSC is limited to the SNR. Are there any other methods that could produce signal detection in very low SNR, very low being -20 dB or more.
RE: Difference Between Lock-In Amplifiers and other Coherence methods
A lot depends upon your frequency range. When we used lock-ins 20+ years ago it allowed us to basically shift our low frequency data onto a carrier to move away from the 1/f noise at low frequencies, and then use the carrier to convert it back down to low frequencies (baseband) with a quieter circuit. If you already have a fast signal and can filter out the low frequency noise then it doesn't really help.
Are you referring to Magnitude Squared Coherence? A quick search shows that is more for higher frequency signals that probably don't have the 1/f problem. Others may chime in with more info.
Z
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
