Can someone explain what the difference is between the Rated Int. and Max Int. ratings for HVCBs?
From my understanding, the "Rated Interrupting" current is the current the breaker can safely interrupt based on the max kV rating. This is then used to compare against the interrupting currents calculated in an SC study.
However, I am not sure what the "Max Interrupting" rating represents and what it would be compared against when performing an SC analysis.
Can someone please clarify?
Shown below are the two ratings for a GE 15kV HVCB
