how to display the load assigned to the joint of meshing
the slab of my model has been meshed and i have assigned loads to several joints.
however, due to the finely divided areas and joints, i am unable to identify which joints in the meshing were assigned with loads.
are the any function/ command in SAP2000 V22 that can display/ show the loads that has been assigned to the joint of meshing?
appreciate any help. thanks on advance.
