linear rails
frank-c
Industrial
IE
I have a NSK, NAH series carraige, 69.8mm x 44mm on a 20.0mm rail.
I have a drawing attached showing the desired position of the rails.
Enquiring if someone can give an indication of max load placed on the bearings in the drawing.?
Just the 90 degree downward load.
Not an area that i'm familiar with.
 https://files.engineering.com/getfile.aspx?folder=1b74b63a-a442-4fc3-989a-3a766e27f0d2&file=CALC.pdf
