Contact US
Why doesn't this power monitor read the AMPS correctly ?
We bought this new power monitor. To test it out we put it on our incoming 208V, 3-phase, 200A service to the office. There's three choices on the CT input configuration: Auto, 150A or 1500A. When on Auto or 1500A it reads 10X the value shown in the pic below. We scaled it to 1/10 - which seems like a more reasonable value for the Amps. Nothing in the manual says to do that however. Anyone know what the problem is ? Why doesn't it work on Auto?
RE: Why doesn't this power monitor read the AMPS correctly ?
Quote (The manual)
When set to Auto, the current range is set automatically and depends on the measured current. Low Range is 1/10 of the nominal range of the attached current sensor. For example, the low range of an iFlex1500-12 is 150 A. High Range is the nominal range of the attached current sensor. For example, 1500 A is the nominal range on an iFlex1500-12.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
We contacted Fluke...if any of the CT sensors are even barely touching any other wire - the results on the meter will be bogus.
So we re-did them one at a time, making sure nothing was touching - and it worked. And btw the reading was way lower than what is shown in that pic above.
I can see the numbers being bad the way the CT loop seems to go into the other CT loop in the picture.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
